Can someone help me with these error codes
cuckoo
61
Newcastle region
VT V6 twin Turbo
Hi got these codes now i know what they are except for 9 but can someone explain what they mean thanks here are the codes
9 -don't know what this 1 means
13- o2 sensor -no signal does that mean the sensor is stuffed or something else
31- theft detterent missing -what the hell does that mean
35- idle speed error- could the be the iac valve or something else
Thanks Cuckoo
vt1538
455rwhp LS3
53
The Dead Centre
VY SS S2 [email protected]
Code 13 is for an open circuit to the O2 sensor. I would be checking all connections at first as you have multiple codes showing. Could be something like a bad earth connection.
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
code 31 - theft deterent signal missing, could mean a few things, such as PCM stuffed, key stuffed or wiring.
I can't find any info about any code lower than 12, you sure it's 9?
Not sure about 13 or 35, maybe talk to holden
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
i think it will be 19 not 9, this indicates an error with the TPS, this in turn can cause the idle speed to be unstable.
31 probably indicates a faulty remote or reader
13 02 sensor RHS no signal, most probably a faulty sensor
Cheers Rob
cuckoo
61
Newcastle region
VT V6 twin Turbo
Cheers Rob
hey doc it was done at a auto shop and he said 9 = stall
i dont know
Cuckoo
kopper69
VRII Acclaim
9 does not equal stall. Dont know where he got that from. A stall can be caused by a number of things and they will usually register a fault with the particular system that failed. ie a Crank Angle Sensor will give the 47. I would clear the codes and recheck them in a week. If they have appeared again, then do something about them. Best starting place is to get a good manual. A gregorys will go through the main error codes with checks and fixes.
