Can someone please tell me if this will work "pics attached"
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
hi people i am changing the rear control arms on a mates vx, and think i may
have run into a problem, i have checked out the control arms on his car and
the ones he has got to replace them,there exactally the same except ,
where the shock absorber bolts up on his one it bolts up from the side
but on the ones he has got to replace his control arms the shock
absorber bolts in from the back is this going to be a problem or can you just
swing the shockie round to the back and bolt it up take a look at the pics
and let me know
what you guys think cheers guys . . .
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
does it still bolt up all sweet if you just spin the shockie around cheers mate
keza87
JCCC NSW Member
34
VX/VY/VZ Wagon LS1
The second pic looks like its from a Wagon!
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
does the wagon diff fit or not ???
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
its got me stumped im not sure why its different
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
any help is very welcome thanks guys
jazza15
Jarryd
Eltham North, VIC
1999 VT II S
I think the key problem is that it is not a sedan control arm. When you buy them from wreckers they usually write 'VT SEDAN' on them, which indicates to me that you may have one from a wagon or ute. So IMO, the advice i would give you is to get one to suit the particular body shape of your particular car.
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
The rear shock mounting on a wagon is different to sedans because the shockies are mounted at a different angle to enable maximum width between the wheel arches on the wagon If the shocks on a wagon were mounted the same way as the sedans, the wagon's load area would be adversely affected.
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
cheers guys
