can ya fit the vz ss z binnacle gauge pod that sits on the dash to a 06 vz ss
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by davidvzss303ksv, Dec 16, 2011.
  1. davidvzss303ksv
    davidvzss303ksv New Member
    QLD
    2006 HOLDEN COMMODORE VZ SS MY06
    Hey guys,
    Anyone know if i can fit a vz ss z binnacle gauge pod to my 06 vz ss commo. If so can i fit it in myself or does holden or a mechanic have to do it.
    cheers.
  2. ojame
    ojame New Member
    VZ Commodore S Ute
    I'm not sure what you're asking? I don't know what a "VZ SS Z" gauge pod is? I was going to assume you meant "S" but there were no gauge pods in S model VZ's.
  3. illlusion
    illlusion Member
    VE SSV MY10
    Yes It will clip in the top no probs
  4. Harris
    Harris New Member
    VZ SS
    If its got climate control with the little compartment on top of the dash iv'e heard that it wont bolt in. Just what it says on Ebay??
  5. Stewlz
    Stewlz Member
    07 VE SSV ute M6
    If its the double hump binnacle gauges off a car with climate control, and yours has climate control it should fit. It's simple to fit all the electrical side of the gauges it simply plugs into a cigarette lighter below the headunit behind the facia, the oil pressure is harder as a small cable has to go through the firewall which is relatively easy if your comfortable pulling the dash apart. The oil pressure switch then has to be removed and an adapter fitted, then the original switch fitted once more as well as the pressure sender, if your handy you would be able to do it, if not do the rest and take it to Holden to connect as it can leak easily if not done right, shouldn't take more than 30 mins labour for them.
  6. aaronevolution
    aaronevolution Donating Member
    Hastings, Victoria
    TURISMO VZ SS 6.0
    You've never heard of a VZ SSZ?
  7. derrro
    derrro haha tough
    VZ MY06 SS
    Binnacle guages!!! All SSZ's came with em!!
  8. derrro
    derrro haha tough
    VZ MY06 SS
    No it won't. You need a different centre/top console. 4Block has recognised this on ebay and reckon that they can get away with charging 500 for a bit of plastic
  9. SH.00.MA
    SH.00.MA New Member
    VZ 5.7L
    Good old 4Block, the prices they charge u might as well go to Holden and pay $10 extra to get the thing brand new
  10. derrro
    derrro haha tough
    VZ MY06 SS
    too bloody right
