Can't get fuel pump relay for my 1984 Calais
bird69
55
Halls head W.A
1984 VK Calais 5.0
Have tried to get fuel pump relay for my 1984 Calais to no avail. Have down loaded the schematic Scott posted up for fuel system but it doesn't tell me what all the pins are for on the bottom of the fuel pump relay. My plan is to do away with the 7 pin relay and may be fit 2 normal relays, is this acheivable? I am desperate to get the ole girl back on the road.
oska
vx custom 600RR
does this help
308Moz
VS SS, VK 5L Berlina
Hey, I've got the same problem. Atm I've got it bridged over where the relay goes and that fixes the problem. But can't get a replacement, everywhere I go they tell me the part's obsolete. What did you end up doing?
markovr
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
You can get one from a efi camira that will fit and is exactly the same . I have one spare you can have for 15 bucks if you get stuck but I reckon you should run the pump power through an additional relay to save the contacts on the tachonomic relay.
heres the camira one i have ..it has a tag on it as it is mounted separately on a camira but you can take the tag off pretty easily to fit it into the base on a vk
308Moz
Ah k, I'll make some calls. Thanks for that. What kind of relay would you run additionally?
Jonno
Vic,
Theirs a few at the wrecker I go to. They charge u like $100 bucks for em tho.. Fk that
308Moz
Yeah, it's about $170 for a new one from bosch. How hard would it be to get a similar relay with its female plug, cut off the old one and swap em over. Or is the price more because its a 7 pin?
Jonno
Vic,
I see ur in Melbourne
I might be able to get u the relay itself cheap if u want. Will be alot easier
308Moz
Yeah, that would be really helpful, cheers man. I'm not in a rush, it's just for my project car.
markovr
northside brisbane
youtu.be
just a standard 30 amp relay so terminal 87 of the tachonomic relay feeds the coil of the new relay and 12v is switched from the new relay to the fuel pump.
