vlturbsk1
Ive recently put a rb30 in my vl wagon and it just doesnt want to start and ive tried just about everything i can think of.
Now what i have changed is:
Engine loom
Ecu
Spark plugs
Leads
Dizzy
Attached adjustable fuel regulator
Injectors
The first problem i had was i was not receiving fuel to the injectors so i swapped the dizzy and then i had fuel squirting out the injectors but very little. So i tested them by applying direct current from the battery and the fired out alot more fuel. In the end i decided to change them anyway but still the same problem.
I checked the psi from the fuel reg i have and there is in excess of 60 psi and even at such high pressure the injectors still wont fire right.
The pulse on the injectors are also ok.
What else could be the problem?
Engine loom
Ecu
Spark plugs
Leads
Dizzy
Injectors
