Car acts silly at 90kms
AUFalcon
Banned
AUII XR6 Falcon
Posting on behalf of a mate...
He owns a VTI Auto 1 2 3 4 all fine but when he gets up to 90 or above the car starts acting dumb....
90kms/h
goes 3rd to 4th then 4th to 3rd and then to 4th does this on and off. What could cause it?
chargedvx6
VY SII HBD Calais L67
If the car has had different diff ratio fitted and it isn't tuned for it then the BCM can shift randomly to find the best ratio
GAMBLR
More trouble than u think
Whyalla (yawn), South Australia
'04 VZ Calais LS1
mine also does that. at certain speeds it flicks between 3rd and 4th. never realised it as a real problem, just move mine into third until i slow down or speed up. spose that doesnt help ya much :p
AUIIFalcon
VT SS
Sounds like something wrong with the neutral safety switch or something..
chargedvx6
Yeah that's it.....neutral safety switch at 90km/h :thumbsup:
greenacc
Searching for the billion
VE Berlina
if this happens going up hills just gear down to 3rd until over the hill. If its doing it on flat roads as well sounds like torque converter. there could be an error code logged for this.
-sbxu6-
-=SBXU6=-
33
townsville
HSV XU6 S2
i havent had this problem with my vt but with my vn i did, it was the auto shift adjustment on the TB, it was set to soft and the slightest throttle touch or hills or what ever would make 3 and 4 shift all the time, i just made adjust it better and all good, not sure if vt's on wards have the adjustment, dont see why not,
hope this helps budd
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
sometimes you could be running low on tranny fluid
kniever
37
greensy, melb
VY II Calais L67 & VN II Calais T5 5ltr
from vr onwards they didnt have that anymore as the transmissions were changed to electronic, on vn/p you could change the shift patterns using the kick down cable as they had hydrolic transmissions but if you want to change shift patterns in a vr on you have to do it in a tune
