Car amps
Discussion in 'Car Audio' started by Beav, May 7, 2012.
  1. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Hi, I want to know what the difference is between a mono block amp and 4,3,2 channel amps?
  2. hakhawk
    monoblock is a single channel amp, hence "mono". they are used to run subwoofers.
    4 channel for 4 speakers
    3 channel for 2 speakers and a sub
    2 channel for 2 speakers.
    there are other combinations possible, but that list is keeping it simple, easy.
  3. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Thanks, thought it was along those lines
  4. Berlina International
    Berlina International New Member
    SA
    9th Consecutive Commodore: VEII
    And bridgeable means you can combine channels, such as the common scenario of setting a 4 channel amp to run as 3 channel for 2 x splits and a sub!
  5. Beav
    Beav New Member
    Emerald
    93 vr commodore
    I just want to run sub so mono block
  6. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Can you use a bridgeable amp as a mono block
  7. coynie
    coynie New Member
    Raymond Terrace
    08' VE Commodore
    Yes but it's more power/cost efficiant to use a monoblock and alot more simple.
  8. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Ok my sub is 1200 watt, any amount of watts the amp should be?
  9. Matt Smith
    Matt Smith New Member
    Sunshine Coast
    VT Acclaim
    I doubt that your sub is 1200 watt RMS, to provide you with a amp model to run that sub we need the RMS value of the sub. What model sub is it?
  10. MAG00
    MAG00 New Member
    VY S2 Calais
    Very possible, but with the 'good' gear people around here seem to buy it's most like a peak bullcrapped value.
  11. coynie
    coynie New Member
    Raymond Terrace
    08' VE Commodore
    You should be matching your amp (rms value) to your sub (rms value). Most models of both items should give you a value for this. So for a 400watt rms sub you should have an amp that amplifies up to that range. If you go a little bit under ( a few volts) it wont make a very big difference, go heaps under and you wont get the sound your sub 'could' be putting out. If you go higher you run the risk of destroying the sub. Hope that helps.
  12. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    It's actually better to buy an amplifier that makes a little more power than the subwoofer is rated to as it's harder to hear a distorting amplifier (clipping) than a distorting subwoofer (bottoming out).
  13. Beav
    Beav New Member
    Emerald
    93 vr commodore
    It is a 12 inch poineer champion series. I was using a poineer class d monoblock amp
  14. AmmoJammo
    AmmoJammo New Member
    Adelaide, Australia
    VL Wagon
    what specific model?
    dual or single voice coil, and if dual, what impedance are they?
  15. Matt Smith
    Sunshine Coast
    VT Acclaim
    Not entirely true, under powering a speaker can be more dangerous than over powering one. If you drive a 500 watt sub with 250 watt and push the amp into dc and clip you will take out the voice coil alot faster than running a 550-600 watt amp. DC/Clip is far more dangerous than over excursion.
  16. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Single. The sub is about 3 years old
  17. AmmoJammo
    Adelaide, Australia
    VL Wagon
    if its a single 4ohm coil, I'd get a bigger 2 channel amp to run it, something like the ReSponse 2x150watt from Jaycar.
    Otherwise, to get a good amount of power into a single 4ohm sub will require a monoblock that does something like 2000watts at 1ohm.
  18. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Alright cheers. I'll have a look into it
  19. DAZ60L
    DAZ60L New Member
    Cambridge Park
    VE SS
    fusion 280 watt powerplants
    Ok guys I have a set of fusion powerplant speakers 280watt...... Splits for the front doors and and 2 ways for rear doors in my ve.....all 280watts what sort of amp should I use and what power.... I'm looking at a 4 channel I know that but what type of amp and power should I look for
  20. Fun_Bucket
    Fun_Bucket New Member
    Cairns White Rock
    Cruze II sri
    280 sounds like the combined handling left and right, 140rms either side from memory. So if you've been reading then a 4ch amp that offers a bit of headroom above that. Do you want me to link you to an amp that cost's $2500? It will do the job, otherwise if not, you need to be more specific about what you want to spend.
