phatvtcom
- Nov 7, 2008
- 280
- 0
- 0
- Location
- south east melbourne
- '99 VT
ITEM: Kicker Impulse IX704
CONDITION: Used
PRICE: $80
DELIVERY/PICK UP INFORMATION: Pick Up only
PAYMENT OPTIONS: Cash On Pickup
CONTACT DETAILS: 0431 293 357
OTHER INFO:
2-, 3-, or 4-channel output
Tri-way capable (Tri-Way crossover required)
frequency response 20-20,000 Hz
70 watts x 4 at 4 ohms
210 watts x 2 in bridged mode
105 watts x 4 at 2 ohms
requires 4-gauge power and ground leads =
speaker-level inputs
MOSFET power supply
two 0-18 dB bass boost circuits centered at 40 Hz
two 0-12 dB treble boost circuits centered at 18,000 Hz
two 18 dB/octave crossovers switchable at 70 or 110 Hz
13-13/16"W x 2-1/2"H x 9-1/2"D
GOOD SOUNDING OLD SCHOOL KICKER AMP THAT IS IN PERFECT WORKING CONDITION. HARD TO FIND AND IS BUILT LIKE A TANK, MUCH BETTER THAN WHAT THEY MANUFACTURE THESE DAYS.
ITEM: KICKER - DX Series 2-Channel Class D Car Amplifier
CONDITION: Used
PRICE: $80
OTHER INFO:
RMS Power Rating (14.4V):
4 ohms: 25 watts x 2 chan.
2 ohms: 50 watts x 2 chan.
Bridged, 4 ohms: 100 watts x 1 chan.
Max power output: 100 watts x 1 chan.
High efficiency MOSFET power supply
Wired Kicker 10ZXRC remote bass level control optional
LED power and protect indicators
Selectable bass boost (0 or +9 dB at 40 Hz)
Mono channel operation
Preamp RCA outputs
Muting circuit cancels out unwanted noise
Balanced differential inputs for noise elimination and factory-radio compatibility
3 Automatic turn-on modes (remote, DC offset, signal sense)
High-density convection heat sink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Low level: 125mV-5V
High level: 250mV-10V
Fixed high-pass filter (100 Hz, 18 dB/octave)
Fixed low-pass filter (80 Hz, 18 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-20,000 Hz
HAD THIS FOR A COUPLE OF YEARS NOW AND IT'S NEVER LET ME DOWN. IN PERFECT CONDITION AND COMES WITH BOX. A GOOD BUDGET AMP.
ITEM: Philips - CMQ405 - 4 Channel 4X75W RMS Amplifier
CONDITION: Used
PRICE: $200
OTHER INFO:
4x75W RMS total output power
Output power (MAX): 900W
Signal to noise ratio: >97dB
Frequency response: 5-50k Hz
Impedance: 2-8 Ohms
Bridgeable 4/3/2-channel connection
Dimensions (W x H x D): 240 x 49 x 373 mm
BOUGHT THIS ONLY 3 MONTHS AGO FOR ABOUT $250. SOUNDS UNREAL AND IS LIKE NEW! PLENTY OF POWER TO RUN EITHER 2 OR 4 CHANNELS. COMES WITH BOX AND WARRANTY
ITEM: Pioneer FH-P6050UB double din HU
CONDITION: Used
PRICE: $150
OTHER INFO:
- Segmented OEL (Organic EL) display
- MOSFET 50W x 4
- MP3 / WMA / WAV / AAC / D-R/RW playback
- Direct AUX-in by mini-jack (rear)
- USB direct connection: USB 2.0 (full speed)
- iPod® direct connection
- Burr Brown D/A Converter
- BMX (Bitmetric Equalizer)
- Built-in DSP
- 5-mode preset equalizer
- 2-mode custom preset equalizer
- Digital sound processing
- Digital listening position selector
- 7-band digital graphic equalizer
- Supertuner IIID
- 2-way crossover: HPF/LP
- Dolby B NR
- Multi-CD control
- Bluetooth adapter ready (Works with CD-BTB200)
- Advanced Sound Retriever
- Direct Sub Drive
- 2 RCA pre-outs: selectable (front + rear/front + subwoofer)\
A GOOD HU WITH EASY USER INTERFACE AND GREAT FEATURES LIKE HIGH PASS FILTER, SOUND ENHANCING, SUB CONTROLS ETC. WORKS WELL WITH A GOOD SPEAKER/AMP SET UP. IN GOOD CONDITION WITH REMOTE AND BOX.
Everything is in good working order and condition. Or take all for $500. Please txt me only since I'm at work a lot of the day. Any more info or actual pics just ask me or google it!
CONDITION: Used
PRICE: $80
OTHER INFO:
MOSFET power supply
CONDITION: Used
PRICE: $80
OTHER INFO:
Preamp RCA outputs
Input sensitivity:
Low level: 125mV-5V
CONDITION: Used
PRICE: $200
OTHER INFO:
Impedance: 2-8 Ohms
CONDITION: Used
PRICE: $150
OTHER INFO:
- MOSFET 50W x 4
- Built-in DSP
- Supertuner IIID
- Dolby B NR
- Multi-CD control
- Direct Sub Drive
