Car bumping slightly
Paintabruh
campbelltown
VR commodore acclaim V6
Hey guys
wondering what the bumping/ shaking if right in the middle of my VR.
Im thinking centre bearing ( ithink thats what its called) what do use think?
James39
Gave up on VL's
Newcastle NSW
1995 VS Acclaim & 1992 Holden Barina
I am sure you did not need to create two threads to get your answer.
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
Hey guys
If when you take a lead off the coil and no change to the engine then this is the dead coil/lead/plug. If the engine gets worse then that coil is OK.
See if you can swap it with a know good unit (DFI & coils).
But I'd say from what you have said it will probably be a coil gone bung. or try your leads
Paintabruh
campbelltown
Thanks just bad how UNO all bout commys? All so mate above just it didn't send thru first time cause comp up that ok wit u?
James39
Gave up on VL's
Newcastle NSW
justbad4you
IF YOR NOT A HOLDEN
