Yes I’ve got an otr so removed everything and maf is seated properly. Car has started but I’m getting error codes but no cel light. It drives beautifully and idles perfectly as well. I’ve disconnected battery for 15 mins let idle 3 mins then off and idle again 3 mins then off not sure why these codes are coming up no light. Tried clearing but still come up.Did you remove the intake to spray the Liqui Moly?
Is the MAF plug fully seated?
Did that for 5 mins and was perfect in fact drove better than before even idles really smooth now. I’ll drive it tomorrow then scan in afternoon hopefully all sensors would have reset.Try taking it for a drive, at least 30mins. Don't baby it, give it a bit!
Seems like it needs to relearn some of the throttle body parameters.
Although not reflected in the app, those DTCs are known as "permanent" DTCs and can only be cleared by the ECU itself after driving through certain drive cycles.Did that for 5 mins and was perfect in fact drove better than before even idles really smooth now. I’ll drive it tomorrow then scan in afternoon hopefully all sensors would have reset.
How long would these take to clear they still show up todayAlthough not reflected in the app, those DTCs are known as "permanent" DTCs and can only be cleared by the ECU itself after driving through certain drive cycles.
Only pending or current DTCs can be cleared by a scanner / code reader.
I’ll wait a few days I guess but really hoping there isn’t something wrong.Could take a couple of days as the ECU has to go through multiple drive cycles before it determines those problems are actually fixed.
