Zack Riley
- Jun 8, 2021
- 48
- 28
- 18
- Age
- 35
- Location
- Sydney
- VL Berlina, VX XU6, VX Clubby, VE Sv6
12,13,14,23,24 and 31. Are what I get.You can scan for codes with a paper clip AFAIK.
With the VL, you have the activate some of the sensors to clear the codes. Errors are what’s left after that.12,13,14,23,24 and 31. Are what I get.
Code 11 - Crank Angle Sensor circuit12,13,14,23,24 and 31. Are what I get.
No need to drop the tank to check or replace fuel pump as the main fuel pump is external mounted just in front of the tank.
The low pressure pump in the tank can be checked by removing the fuel sender plate.
The LED flashes in the ECU aren't fault codes but more like status messages.
The tank can be drained by removing the lowest bolt on the fuel sender plate and have a container with a funnel or tray underneath.Thanks for that, I have ordered both.
Its actually looking like this could be the main problem. Can't hurt to swap both pumps out. but if its the internal one I may leave it for now.
