Car jerks under throttle
andrewmac
S2 VE SS
Hey
I have a prob with my Vs which is when i accelerate to high throttle the car doesnt rev properly it jerks back and forth not back braking jerking but you can feel it and i can see the tacho is not going up smoothly it also jerks up aswell.
Under normal acceleration its fine but overtaking and heavy throttle messes it around.
I have absolutley no idea what this could possibly be.
Any help would be great.
JD
Donating Member
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
fuel injectors may not be pumping enough petrol in the engine casuing to spultter and jerk.
andrewmac
S2 VE SS
I doubt it is that cause i had the injectors cleaned at the beggining of the year but i suppose a botttle of spitfire through it couldnt hurt.
Any other ideas guys, i have also checked for codes and nothing.
J_D
Ipswich. QLD
VN S1 and VS V8 Statesman
Fuel filter blocked maybe?
andrewmac
S2 VE SS
Now theres a thought i dont think its been changed since ive had it (just over a year).
Thanks for that i will definatly look at that one.
digisol
Central QLD
Toyota Landcruiser
To be serious the fuel filter should be changed when you change the oil and it's filter, a new one makes a huge difference in power and fuel use.
Likely the filter is 11 years old and definitely needs changing.
Immortality
Staff member
Sth Auck, NZ
it does sound like a blocked fuel filter but it could also be a high speed ignition miss. what condition are the plugs/leads in
cypher967
HSV VT 5.0 195i
VS Commodore S
Could be because the engine is missfiring, thats what was wrong with mine a few months ago.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
It could also be the standard (no extra cost) shudder on hard acceleration found in most VN to VS Commodores though this is generally worst in 1st and 2nd gears.
Immortality
Staff member
Sth Auck, NZ
could be even though it shouldn't have, maybe some sort of manufacturing fault where something in the driveline doesn't quiet line up or something. prabably not this however if he didn't have this problem before
