Car losing power...
Fresh SS
VY SS+Turbo
Hiya Guys,
Hoping somone might have had the same problem..
If i feed on the power in 1st or 2nd it feels like it periodicaly losses power sometimes it does it if i just plant it..
Any ideas would be great!
Luke
P.S i have a vy ss list of mods are in the my ride section (If the mods have approved it)
caaf
Melb, Vic
www.aurfscan.com.au
VYII Equipe S/wagon V6
It can be many things.. Failing/failed fuel filter (released contaminants ending in blockage) . Failing fuel pump, not supplying high enough PSI to the rail. If MAF installed they to can fail and give incorrect readings.. You yourself have to start doing some testing. If you don't have all the required testing tools it may be time to visit a service technician.
note. without a link to your car's details, not many people will bother looking for it ;)
It's easy to do - example's shown here ;)
Fresh SS
VY SS+Turbo
Thanks for the reply,
I changed fuels and it now works fine. i was using E98 (Ethanol 98 octane) changed to shell v power.
danja
Swerves for gay koalas
CBF 250 and a Levin ZR
If it comes back, try turning traction control off.
Baldric
The BOSS
VE GTS M6
its just a bad batch of fuel. and your pcm has dected lesser grade fuel and has dropped the spark down to low octane table (less timing) and when you switched to a better fuel quality. it goes back to high octane :)
maybe check your fuel filter as well
Junny
purrrrrr
VUII Maloo + shitty painted vp
isnt ethanol bad for ur car? vpower FTW
alien
Tullamarine, Vic
03 VY Supercharged 3.8L
Ethanol tends to do bad things to the engine. If you can run Mobil 8000 through your car a bit [usually 3 tanks gets all the crap out]. Mobil 8000 is tried and tested as the best fuel on the market and has plenty of cleaning agents in it! I used to run vPower, swapped to Mobil 8000 and my acceleration increased. Now it's the only fuel i put in my vehicle!
Fresh SS
VY SS+Turbo
I run a servo (Freedom Fuels) And they swear black and blue that Enthanol is good for your car, even the handbook says you can run it.
As for mobil 8000 never heard of it?
Probley not here in Traralgon
Baldric
The BOSS
VE GTS M6
mobil 8000 is the higher grade 98 ron as far as i know
minux
Infidel Bear
You do know Mobil 8000 is just BP ultimate right?
Since shell have altered the vpower blend, I have gone back to it, was finding too many inconsistent batches of Ultimate/8000.
