Car overheating?? / thermo fan not working
Endz
Sydney, Australia
VP Executive
Sitting at the servo tonight waiting to get fuel, an noticed smoke comming out of my centre aircon vents, then looked over at my temperature and it was neer the top, so i popped the bonnet to fid that the thermo fan was not on. I tried changing my horn fuse with the fan fuse & it still did not work. So i let my car cool down for abit before i drove it home, then on the way home when sitting at the lights it would get very hot but when driving it would cool down to average, i recently replaced the terminals could i have disturbed something ? Or could my fan have **** itself, anyone got any suggestions? Havent had a problem like this before.. Thank you! Its a 92 VP if it helps
hi_ryder
Donating Member
Pascoe Vale South, MEL
you can test your fan directly off the car battery to see if its pooped its pants or not...
if youve messed around with it recently make sure you didnt accidentally bend or mess up one of the connecting prongs for the thermo fan plugs. make sure there making contact. think someone else on here had a similar problem, all he has to do was bend the connector back to shape so it would make contact.
also the car has 2 temp gauges one for the dash cluster and one for the ECM. it might be the one for the ECM has failed. if you undo your drive belt and lift up your alternator its right there, has a blue square head same shape as the one for your fuel injectors. if the first 2 things dont work it may need replacing...
Endz
Sydney, Australia
VP Executive
Thanks alot for the help, will try this tomorrow and let you know how i go!
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Check the fan fuse next to the relays.
Endz
Sydney, Australia
VP Executive
I cleaned up all the connections and its working fine now, i think it was just a pooor connection somewhere, thanks guys
