car turns off?
msina1
VS acclaim,
just returned from footscray with a mate after he bought his new vs, drove back down to geelong, whilst driving round the geelong area the check something train light came on, after a bit more driving, every time when pulling up to the lights it would just shake a bit and turn off, turned back on first time?
any help?
clubby_you
brisbane
vs clubsport
check your battery terminals
msina1
VS acclaim,
will do, but if they were loose wouldnt the accessories and such turn off also?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
msina1
VS acclaim,
apparently the dealer told him it was the o2 or OS censor (no idea whichm)
Ozzie
JCCC Warrnambool
Warrnambool
Ozzie'z Supercharged VY Calais
You can pull the battery out of the car once running and it wont do ****.
The car runs off the alternator not the battery.
If you had a stuffed alternator and the battery terminals were loose then it wont start again.
And yes sounds like the O2 sensors playing up.
msina1
VS acclaim,
well, suppose we'll find out tommorow, dealer said he'd fix it,
alex2_s
Newcastle NSW
VFII SV6 Sedan Auto
Start your car up and just undo the negative battery terminal.
Chris E
Vr Executive 3.8
Ozzie if you disconnected the battery you'd break the circuit and your car would stall. Carby cars can run with a flat battery because they don't need any power for the ecu and such. Some diesels can run without a battery because they don't need spark.
Don't mean to be lecturing or anything tho
