hello i have a vt wagon i connected a tech 2 up and now my wagon will not start my radio works, i have no power in my obd2 plug, i can not lock my car iv tried all fueses realays tried a new bcm low mine was a mid can any one give me an idea please
Question time...... When you say; "will not start", do you mean the engine turns over, or there is nothing at all? Do you have ignition lights on the dash and do all the other accesories work? Did it run before you connected the Tech 2? Maybe you inadvertently deactivated something with it? This is not for a Commodore, but is interesting....http://my.is/forums/f115/01-is300-car-cranks-no-start-up-obd-ii-wont-connect-462041/
Just a thought; You didn't damage the obd receptacle with the Tech2 connector did you. It might be worth checking it for damage.
hey thanks for the reply. the wagon ran before i hoked the tech 2 up all my ignition lights light up, radio works , car will not crank nothing at all never got to turn tech 2 on
check the fuses both the ones under the steering column and also the ones in the engine bay. Gotta be that.
thanks for wire diagram Nut Kracker. im half way their i swaped pcm/ecu between my sedan and wagon both ways i hocked up the tech2 to to sedan and mearged them together no prob car started straight away(in the sedan). took tech2 to th wagon and i now have power in obd2 plug (using sedan pcm/ecu) tryed to mearge pcm/ecu to the bcm no luck tech2 unable to merge the two no cummnacation to pcm/ecu so now my problem is a bit easyer but still not quite their with the sedan pcm/ecu it cranked once and now nothing?
