Car wont change gears, holds gears, and rough changes
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by pedrotski, Sep 3, 2008.
  1. pedrotski
    pedrotski Big Stato!!
    Mandurah
    95 & 96 VS 5L Statos
    Hey guys,
    This is puzzling me.
    I have a 1995 VS Statesman and the car seems to loose gears. When its in drive, It will only use 3rd and 4th. But when i use the selector, It will change into any gear. Just rough. If i turn the car off and back on again, The gears will be back to normal.
    Any ideas?
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Your car is probably in Limp Home Mode - look it up on GOOGLE for a full explanation.
  3. pedrotski
    Mandurah
    Yeah im pretty sure that either my trans was getting to hot, or im low on fluid.
  4. Cursed CX8
    Cursed CX8 Banned
    Walking distance to FG meets
    VY Adventra
    take it into a trans/auto specialist and get them to service it and check for any fault codes. Shouldnt cost too much
  5. hako
    Toowoomba SE QLD
    VS11 BT1 V6
  6. pedrotski
    Mandurah
    How much roughly.
  7. hako
    Toowoomba SE QLD
    VS11 BT1 V6
    A service will cost between $140 to $200 plus when they download the codes - and given your description there will be some, - they may say 'time for a recondition'
    It could just be a solenoid gone in the trans but as stated before, you can check the codes yourself and that way you have some idea of what could be wrong and how much it will cost, otherwise you will be at their mercy.
  8. manual crazy
    manual crazy New Member
    sydney NSW
    95 manual vs s pac
    the tradesmans at my old work gun'd it off at the lights in the the work ute in wet and and spun the tyres in every gear it was mad ! and he also mad ****ed up the gearbox and now it is doing the same thing that yours is doing lol
