Car won't start
djdomohudson
Mad frogs
Werribee, VIC
VE Omega Sedan / VE International Sportwagon
Took the car into the city on Saturday. Later on that evening back home I needed to move it to let out another car in the driveway and it wouldn't start.
It's done it to me a few times. I turn the key all the way. There is one quiet "tick!" that comes from the engine. Nothing else happens. Inside the car the interior lights, stereo, Air Con etc. all work still.
Previously with jump cables and another car I've gotten it to start again but this time after several attempts on Sunday it still wouldn't do anything. The only progression was that there wasn't only the aforementioned "tick!" but also a sort of very quiet "hissss" for a second or two...
My current diagnostic is just that the battery has had it.
What do you think?
supercharger kingy
NUCKIN FUTS
35
KIAMA
VE L98 Calais
Starter motor .. bash the solinoid with a hammer then give it at go..
if it works after that then u need a new starter...
supercharger kingy
NUCKIN FUTS
35
KIAMA
VE L98 Calais
yeh the Solenoid can get seized inside.. just give it a couple of bashes with a hammer or a spanner anything really.. see if you can loosing it up... then try and crank it over.....
sounds like a starter motor.. the battery doesn't seem to be the issue if the radio and all that still work ...
the stater solenoid the the round cylinder on top..
also check that the NUT that is connected to the ground wire is tight and not arching out anywhere... i would also check and clean your battery terminals
djdomohudson
Mad frogs
Werribee, VIC
Oh that's the solenoid.
supercharger kingy
NUCKIN FUTS
35
KIAMA
VE L98 Calais
No that ur alternator ...
ur starter motor looks like this - http://compare.ebay.com.au/like/160746997394?ltyp=AllFixedPriceItemTypes
if you have volt meter gauges check out the volts coming from the battery aswell... just cause ur radio works doesnt mean the battery is dead.. it takes a certain amount of volts to start the car and not so much for the radio etc
commodorefanatic
VT Commodore Olympic Edition
yer, that's your alternator dont hit that. Your starter motor is underneath the right extractor, it will be easier to access from underneath the car. give it a good old wack and she should come good. Not a permanent fix but it will get you moving again so you can get another one!
Good Luck
djdomohudson
Mad frogs
Werribee, VIC
LOL OK. Learning. I'm not a lost cause. I've done a lot of stuff to my engine and learned heaps seriously.
Teach a man to fish and all that.
Point me out? Also for the earth wire please. I was having a search on google for the earth wire and didn't really come up with any clear answers...
djdomohudson
Mad frogs
Werribee, VIC
Good Luck
Yeah I won't hit it... lol.
So, underneath the car eh.
Won't waste my money on a new battery just yet if it's not the battery. Better call around for starter motor quotes.
supercharger kingy
NUCKIN FUTS
35
KIAMA
VE L98 Calais
yeah mate as stated underneath the car under right extractor... the ROUND CYLINDER PART ON TOP WITH THE WIRES GOING TO IT is the SOLENOID .. give it a couple of bashes .... it still could be a faulty battery or even loose or dirty battery termanls.. check them first before you go whacking (excuse that term unless ur in the mood to i guess )
