car wont start
urmyho
37
vr bt1
hi
i wash my car yesterday and then drove it back into the shed and it stalled on me. its and auto. and now it wont start does anyone have any idea where to start looking for the problem?? i have checked for fault codes and it just came up with 12.
car is a vr bt1 5ltr
thanks
urmyho
37
vr bt1
yes i did just near the battary
what did you do to fix the problem
urmyho
37
vr bt1
cranks over just doesnt fire
jafo
lurker since 2003
adelaide
1999 wh statesman
check the fuel pump
get someone to sit in the car and you go to the rear when they turn the ignition on you should be able to hear the pump from the fuel tank.
if not bang the tank and try again if nothing replace fuel pump.
Double G
VS Commodore
Same thing happen to me the other day...I called out the RACQ and the mechanic cleaned out the DFI module connector plug...after that it started first go.....
urmyho
37
vr bt1
fuel pump works
hhuumm whats the dfi module
thanks for all your suggestion guys
bluecar
68
rural victoria
VS EXECUTIVE WAGON
did you get her going old son?
If you haven't try a test light between the ignition module and the coil terminals. It should flash when you crank it.
If it doesn't you probably have a bad connection there some where.
ps I'm no expert.
urmyho
37
vr bt1
na haven't got the car goin yet
thanks for the suggestion ill try it and see what i find
