carbied v6 non ecotec
dirttracker
vn speedway car
hi guys wondering if any one can shed some light on ,hard wiring vn dfi unit and setting advance
so i can run custom 4 brl manifold for speedway use
cheers jim
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
just run the ecu as spark only control gives you fully programmable ignition for free leave all the sensors attached and add athe tps sensor ontp the carby butterfly shaft and shes good to go.or if not you are stuck at 10 degrees timing all the time and can adjust timing by moving the crank angle sensor but its hard and not the best way.or you can buy a control box from the states but that isnt cheap
