Carb a Holden V6
Triple down draught Webers!! :yeah:
Anything is possible.. just not "bolt-on" for many good reasons.
#1 - It comes factory EFI...
#2 - EFI is good and easily tuned.
#3 - A dizzy? :hmmm: why ditch the direct fire ignition? it's worlds better than a dizzy. GM spent moonbeams developing DFI. It's more accurate and carries alot more current - better spark, better bang!
#4 - why not just get a Chev V6 or a dirty old 308 they carb and dizzy standard :rofl2:
Having made those points clear, if you did carb but stayed with the Delco to control the DFI, the Fuel tables can stay, as "fuel" in the ecu wouldn't be used. Just leave the injector wires unconnected.
You would have to use the MAP sensor connected into the manifold for load reference (tapped into all six runners for Webers) and a TPS on a Carbs throttle shaft so ecu knows throttle position (idle, back off & WOT)..
Change fuel pump to low pressure/high flow or reduce pressure of stock efi pump with a regulator.
Jet and tune to suit! :spot on:
