hi there just wondering if anyone can help me out on installing a cargo barrier into a 97 vt .:hmmm: this is the one that im having trouble with....
I think you need to be a bit more specific. What exactly is causing you trouble with the installation?
How are you havin trouble with it ? The top ones ya just put into the holes and twist as ya push them in on the springs and the bottom ones ya might have to move the tags to line up with the holes in the floor if the car has never had a barrier fitted the bottom holes might have a plastic cover in the holes just remove the cover and the bolts that I use were in the part were the jack is the long arms on the barrier are for when you use it behind the front seats with the rear seat older down and they screw into the same holes in the floor as the little tag do when in use behind the back seat.
