Castrol edge
Murdoch
VF II SSV Wagoon
let me know how you go/suitable.
I used to run 10/60 in my unopened LS1 and it was the best I found for reduced noises.
10/60 in an LS3 though i'm not sure unless you have heaps of Km's?
Ron Burgundy
NSW
VF II SS
Only 27000km
BlackVXGTS
Melbourne, SE
Why don't you just use Penrite Enviro+ GF5 5W30. It's fully synthetic, Dexos1 certified, and available at a reasonable price - around $53 for 5l and even cheaper when on special.
Murdoch
VF II SSV Wagoon
Only 27000km
yeah that's stuff all
these new oils must have unbelievable sheer characteristics
blown hsv's I think still have the thinner stuff and are pumping out what 600 hp?
Batca
Vf ssv sportwagon
I run Castrol Edge 5-30. The engine is quiet and no complaints. It's all I will use now moving forward with leftover half bottles so I buy more. TBH I don't think the Penrite would be much different they are all good quality oils these days.
426Cuda
SUBLIME!
Wagga Wagga
VF Redline Sedan - A6 Spitfire MSE...
I usually stick to the manufacturer's recommendation re oil grade / weight. Changing it up can void warranty. Penrite all the way. But I like Nulon too. That said, I once filled my low k L77 with Penrith 10/10ths. It sounded like a chaff cutter. I put 5w30 Enviro straight back in and it's sounded sweet ever since.
Phawk
NZ
VF11 SSV Redline
I use Castrol 4T in my Bikes, but I've only used Penrite in the SSVR
blackve76
47
there
VE SS ute 360rwkw N/A, 2016 VF2 SS M6
Just for any penny pinchers like me got 5 X 5w40 5L Castrol edge from Supercheap for $140. Spend $200 get 30% off they are $40 on sale atm.
uniacidz
Harden the Frak Up
Sideneee
VE Berlina
In my LS1 the Catrol 10w60 made it noisier but that apparently is normal
Have Castrol 5w30 for the VE V6 and hoping its not gonna be a noisy goat
Otherwise had great success with Liquimoly and Penrite
tml678
2017 HSV30 Senator, 2002 Corolla..
Big fan of liqui-moly products, and I've been keen to try their oils, but can't find any Dexos rated ones available here in 5w-30 (I'm sticking to manufacturers recommendations). How do you compare it against the others and which weight have you used?
