Catalytic Coverter needs Replacing!
dean13
VE SV6
Hey guys,
One of the oxygen sensors in my 06' VE SV6 was causing the Check engine light to stay on. Took it to Holden and they said that the converter is 'disintergrating'. Does generally happen to converters over them and how much does it usually cost to get a new one and have it installed? Holden quoted me at around $1000!
aaronevolution
Donating Member
34
Hastings, Victoria
TURISMO VZ SS 6.0
Hey guys,
Should cost no more than $300 including install from a proper exhaust shop.
dean13
VE SV6
thanks mate, found a place that would do it for that price!
Troy711
Retired Old Fart
Canberra, ACT
forums.justcommodores.com.au
2011 Mitsubishi Pajero GLS
Cheap fix is to remove it and bash the guts out with a broom stick. Be prepared to hear 'deeeerrrrrrppp' every time you put your foot down though. And also carry a box of condoms just incase EPA catch you.
mikey-
Perth, WA
VE SS Sportwagon
Have you considered buying a second hand cat?
Although not as popular in the SV6 as the SS, I'm sure people still replace the cats with highflow ones.
mikey-
Perth, WA
VE SS Sportwagon
Not everyone likes having unroadworthy cars.
My point being was buy the STANDARD cat from the person who has replaced it with a highflow.
And because 200cpi cats are just totally unroadworthy.....
RiCeY
F O R U M W A R R I O R
Australia
VZ SV8 6spd 6.0 430rwhp
Have they tried replacing the gaskets first as this is a common problem and should be done before replacing the cat/s.
The codes will reflect an issue with the cat when its actually the gaskets leaking and messing with the readings.
dean13
VE SV6
yep had the gaskets replaced and then the codes were still coming up
