Catch cans
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Alex05, Aug 2, 2012.
  1. Alex05
    Alex05 Member
    Ve sv6
    Gets looking for a catch can. What are ppl running in their setups. Have a alloytec. Heard elite engineering are good but pricy. Will cheap drift brand work or will I have to fill it with steel wool. There is a company selling baffled catch cans but retail 120. Anyone interested in a group buy?
    Company original auto parts.
  2. Mattk101
    Mattk101 New Member
    Ve sv6 sidi 2010
    I have one of those from opg, it works which is a plus ha ha. Comes with steel wool already in it aswell.
    Only bad thing about it is the mounting hardware it comes with isn't the best, but it does the job
  3. Alex05
    Alex05 Member
    Ve sv6
    Do you reckon the opg catch can is worth it or better getting a cheap one and filling it with wool myself
  4. V SPEC
    V SPEC Member
    Darwin
    VE Calais V
    Rx performance can, and breather kit.
    Little exe, but ain't any good running a half arsed setup.
    And I hope that you intend on mounting it correctly, not just inline with the clean air line that comes from the air intake pipe.
    If you read this link, it should give you a nice insight.
    http://Forum.grrrr8.net/showthread.php?t=16756
  5. Alex05
    Alex05 Member
    Ve sv6
    Yeah definitely gonna do it properly but don't have a huge budget for a can. Was thinking the opg can.
  6. WogBoyz
    WogBoyz 435rkw/590rwhp
    Cairns, Qld
    08 VE SSV M6 Ute
    Ive got an elite engerneering can on my ss and there well worth the coin, very good quality and work very well! deff recommend them
  7. Alex05
    Alex05 Member
    Ve sv6
    How much you get it for landed in aus wogboys? I only have a stock v6 with Orssom otr so is it necessary to spend big or will a basic one work fine
  8. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Oh man i cant remember ay this is going back a yr or so i cant remember if it was $120 or $220 to my door lol i didnt get mine from USA tho I emailed Elite and they gave me a link to a mob in Aus that sells them, so i just got it from that mob
  9. bigjim92
    bigjim92 Active Member
    2016 VF SSVR
    On my SSV I've got an Elite Engineering catch can, love it! Blends into the engine bay very nicely and looks stock, as for how well it works, it's only been on the car for 3 weeks (about 500kms lol)
    I think I paid $230 delivered from Justin at Tuff Car Parts.
    On my SV6 I've got a cheap Drift Catch can, still need to connect it up and get some sort of steel wool etc for inside, paid $80 or something from Autobarn.
    Comparing the Drift can to Elite, Elite is definitely the way to go in regards to quality!
  10. Beav
    Beav New Member
    Emerald
    93 vr commodore
    What do these catches do? And are they a performance mod?
  11. bigjim92
    2016 VF SSVR
    They're not a performance mod, but they help maintain performance.
    You have a breather line that runs from your rocker cover to your intake system.
    Gasses and oils get sucked through this breather line, and oil has a negative effect on everything, economy, performance etc.
    A catch can does what the name suggests, catches the oil so only gasses enter the intake system.
    On a direct injection motor a catch can is very important as oils and sludge will continue to build up on the back on the intake valves.
    This shows the difference between having a catch can and not having one,
    Results after 5k miles CatchCan use: - Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com
  12. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Adding to this, the hot oily air can reduce the ron rating of the fuel ect in some cases, i cant rememeber where i read that but i was like :O not good lol
  13. bigjim92
    2016 VF SSVR
    Correct, oil reduces the octane rating, so it'll have a negative effect on performance and economy as I mentioned :)
  14. WogBoyz
    Cairns, Qld
    08 VE SSV M6 Ute
    Yesss i was hoping what i read what right lol so morale of the story everyone is, get a catchcan! not too expensive and can help quite a few things!
  15. Beav
    Beav New Member
    Emerald
    93 vr commodore
    Bigjim92 thanks I get it now
  16. Alex05
    Alex05 Member
    Ve sv6
    Just received My elite catch can. When I install it should I run some upper engine cleaner through the motor to get rid of some of the built up oil and sludge
  17. bigjim92
    2016 VF SSVR
    YES!! You would be shocked if you removed your manifold and saw all the crap that's built up!
  18. Alex05
    Alex05 Member
    Ve sv6
    I pulled the intake manifold recently do fit mace spacers and gave it a clean but will run some Subaru upper engine clear through too.
  19. nickb1993
    nickb1993 New Member
    sydney
    ve sv6 ute
    Anyone got some pics of where to mount them?
    And what to use to mount it as im gonna do this in a month or so and getting ideas whether something of the held is suitable for a mounting bracket or make something custom up at work?
    Probably will be an autbahn drift can with steel wool inside which wool is better thick or fine wool?
    Thanks
  20. nickb1993
    sydney
    ve sv6 ute
    Oh i forgot to mention its on a 2010 sv6 sidi ute has stabdard intake on atm but have my otr to put on in september wen i get my licence back and get it tuned
