Central Locking Actuators
jgtoranalc
Adelaide, SA
Holden Statesman VR HSV 5L, Holden Torana LC
I am looking for a Central Locking Actuator for rear door. I have found 2 on eBay but they say check your plug before checking, it's currently raining outside so I can't be bothered removing door trim and checking it while getting wet. So I thought what does the plugs look like...does anyone know what exact plug is for what model
I do know from VN-VS have the same actuator... would it be the VN-VP to be different to VR-VS?
Any pics?
jgtoranalc
Adelaide, SA
Anyway I did searching and I found that VN-VR are the same but VS are different....
Demonica
Donating Member
SE Qld
VS clubsport
They aren't that much different. Only difference is the tiny little rubber at the top (circle vs oval). Both fit fine but if you are anal about it it takes literally 1 second to flick the rubber out and put the original in. I bought a full set of brand new VN actuators off ebay for $70 a while ago and they fit fine. Plug was exactly the same.
