85berlina
- Jun 27, 2006
- 137
- 3
- 0
- Location
- Sydney
- VK berlina sedan 202
The interior light thing is actually for where the door trigger connects to. The interior light thing does apply. This is because the door trigger on the alarm connects to the door switches and the door switches connect to the interior light. Its not the interior light that matters, its the switches they are conencted to, the interior light was brought up before so don't get confused. Just connect to the door trigger to the back of one door switch.
With the indicator lights, the trigger wires just need to connect anywhere after the indicator switch. Where to connect to after the switch totally depends on where the alarm module is located. In a 1998 corolla I did an installation in, I mounted the module behind the drivers side kickpanel right next to the drivers right hand foot. In this case I connected the wires directly after the switch in the steering column. In my car, the module is mounted behind the passengers side kick panel. In a VK (Unsure about a VH) the main wiring loom passes through the firewall on the passengers side so the wires for the indicators pass through that loom. So this is the closest place and I made the connection here.
Imobilisation points are places where the relay immobilises a certain system by breaking the power input into the device. In my VK, which is a stock standard berlina with a carby and the computer has been removed, I can only immobilise the ignition and the starter motor. If you have an electric fuel pump, then that can be immobilsed or any ECUs if they have a disable wire (Be careful with ECUs).
You do literally cut the wire and put the relay in place. Don't ever cut the ground wire and immobilise that because then you will get wierd ground loops etc. Always cut the 12v input to the device. Remember that a relay is actually a switch so it is switching the device off to imobilise it.
With the siren, a fuse isn't necessary but if you have one in and it doesn't blow when the siren is on, it will still function fine. However, it is a backup battery siren that you have. This is the better type of siren to have because with the standard sirens, a thief just has to open the bonnet and cut the wires. If they do this with your siren, it will sound. It sounds when triggered from the alarm or when 12v power is removed. So, if the fuse blows, it will diconnect power from the siren and the siren will sound. You will have to pop the bonnet and put the key in the back of the siren and turn it off. This would happen at the most inconveniant time of course such as 1 in the morning.
