Has anyone removed the centre console in their VE? I want to install the compartment with the spring loaded door below the radio in my SS-V to replace the empty hole that's there at the moment. I presume I need to remove the gearstick surround, and it looks like there are no screws, so guessing just a 'pop-off', but dont want to force it. Also not sure if I need to remove anything else Thanks
I don't suppose you have the part number for the door or any other bits that you need? I want to do the same thing for my SSV. From memory, the whole centre piece is just clipped in down each side. A firm pull up should do it!
Ashtray Option! Hi, I have bought the ashtray/cigar lighter option for front and back. My requirement was for additional power outlets - GPS, mobile, kids' IPODs and DVD player. The kit includes fitting instructions, though I have not got around to installation yet. The instructions say to use a trim removal tool, and be very careful. It is correct that this bit of trim should "pop" out if correctly tickled. If you want, I could copy the installation installation instructions for you, and post them here. Please advise.
I've since gone and tried to fit it, and yes, the centre piece does just lift out. There are three plugs that need to be disconnected, and they're on very short leads. I managed to get them out - - Traction control - small insert needs to be pushed in so that plug is released - Electric windows (White) - squeeze and pull - Mirrors (Black) - squeeze and pull Getting them out was hard enough, getting them back in again was a nightmare! If you can, get hold of someone with small hands! I was trying to put in the compartment from a Calais, but before you go ahead yourself, a couple of warnings - - The colour doesnt match! Once you put them close together you realise that the SSV dash is black, but the Calais door is more of a dark grey colour - I just couldnt get it to fit properly. No matter what I tried, I couldnt get it to lock in and sit properly. Either I'm just useless, or they're not quite the same fit as the original. I ended up leaving mine in there, as I wanted it to hide some cabling I've got in there. I dont need to open and close it, so the fact that it doesnt fit properly doesnt bother me too much. Although it's a shame it's not the right colour match, it's a damn sight better than the nest of cables that it's hiding! I'd already installed by the time I saw your message, so didnt get a chance to note part numbers, sorry.
Thanks, I'd love to see the instructions to see if I can do a better job of fitting mine. I didnt need a tool to remove the centre piece around the gearstick, just gently prised a corner with a small screwdriver, then slid the screwdriver around the edge, lifting each of the clips in turn
I know its not the right set of instructions but it should help. http://jhp.com.au/manuals/JHP-G8-Sports-Gauges-Instructions.pdf
i really want to put a headunit down in the same place i really need to see those instructions but for sum reason i cant open the file can you repost it please
Looks like the link has been filtered/censored for some reason. Try this one http://############/g8partsdirect/InteriorAccessories/JHP-G8-Sports-Gauges-Instructions.pdf The system is obviously censoring links for some reason. Replace the hashes with jhp_dot_com_dot_au
Just wondering how I remove the side panels from the console? I am trying to get to the power supply that goes to the cigarette lighter.
