ceter bearing problem? or normal?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Mar 19, 2012.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hi wjile under car i noticed that my center bearing has allot of play it it, like if you grab the tail shaft and push it up and down etc where the center bearing is it moves up and down etc, HOWEVER the ceter bearing rubber is intact just movement
    is this normal? i have a spare but want to know if there supposed to be like this
    cheers
  2. juiceie vh sle
    juiceie vh sle Member
    roxby downs
    VH SL/E..VF2 redline W375.. 200 series landcruiser
    if the rubber is all good with no splits or looking perished and there is no vibration and it spins free and smooth it then its fine.
  3. UW1SH
    UW1SH New Member
    If it's got play then ditch it and put a new one in. Probaly needs it anyway they are suppose to have pretty much no play so if it's got play but your rubber is still good then maybe inside has something wrong..
  4. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    If its got play you'll notice when you take off a shuddering sort of feeling for a few seconds. If not i wouldnt worry about it.
  5. jas98
    jas98 Active Member
    maryborough QLD
    yeh i got a shudder, at speed to, just seems like the rubber has gone soft over the years, im gonna replace it anyways
