ch ch ch ch noise on start up - alternator?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by timmy_tam, Nov 24, 2006.
  1. timmy_tam
    timmy_tam New Member
    VN calais 91
    got a vn 91 calais
    lately, on start up, it makes a ch ch ch ch noise
    went for about 30 seconds
    i can see the alternator just flicking, sorta like it's seized
    when off, the battery is about 12.15 v
    when on, the battery is still around 12.8 v
    does that mean the alternator is stuffed?
    or could it be more, such as starter motor?
    what does a new alternator cost?
  2. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    Belts and pullies OK? Brushes in the alt can cause the alt light to flicker.
  3. timmy_tam
    VN calais 91
    the alt light on the cluster dash?
    haven't seen it
    what does it look like?
    and do u mean the brushes inside the alternator itself?
  4. 88GreenVN
    Surprise, Arizona
  5. VNV6VENGEANCE
    VNV6VENGEANCE VeNgeance
    adelaide,sa
    VN Turbo
    he means the fins and the belt. Mine does it occasionally. It can come from all sorts of things. A retardation of the ignition timing caused usually by leads. Check lead votlage. then get back to us.
  6. timmy_tam
    VN calais 91
    yeh, thats right
    the fins on teh alternator
    how do i check the lead voltages?
    disconnect the lead, put the positve of voltimeter to lead and negative to ground?
    could it be spark plugs?
    i keep thinking it's alternator...?
  7. timmy_tam
    VN calais 91
    okay, i've gone and cleaned all the battery connectsion back to bare metal, inclduing the connection at the back of the alternator at the suggestion of a member on JC
    and it seemed to work, car started up normal again
    but just now, it started doing it again, the ch ch ch on start up
    i'm pretty stumped, anyone have any ideas?
  8. JD
    JD Donating Member
    Deep South, SA
    1.6L Turbo Holden Croooooooooooze
    go to a wreckers pick yourself up another one they only cost around $20
    less screwing around
  9. timmy_tam
    VN calais 91
    okay, turned out to be oxidised connection at back of the alternator, which was draining my battery on start up
    a 10 mm spanner, sand paper, conductive grease and a recharge had the vn baby purring like a tiger again :D
    thanks VT97 :D
  10. 88GreenVN
    Surprise, Arizona
    Good old grease on the connector - good for battery terminals too.
  11. vks
    vks New Member
    1990 vn 3.8 S pack
    when the engine is running and the alternator is charging the batt should be up round 14 or 15V.
  12. 88GreenVN
    Surprise, Arizona
    Did the test on the L3 dash and got 13.9v - that the one that gives you the digital speedo on the VN and pressed mode 1 time to get the volts.
  13. defa
    defa New Member
    VN Commodore
    wouldn't want to have it charging at 15..14 is any amount..
