Change auto filter and fluid - cost of DIY vs. get it done
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Circlotron, Jun 22, 2012.
  1. Circlotron
    Circlotron New Member
    VP Exec 5L BT1 ex cop, ex taxi
    Awaaaaay back in 1984 I changed the fluid, filter and gasket on the HQ I had at the time and it cost me close to $40 all up plus about 1-1/2 hours go to whoa plus a bit more time because I had to go buy the stuff. I could have gotten it done for $50. I am thinking the VP needs the same done now. What nowadays are the costs of DIY vs. go get it done?
  2. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    Auto Transmission service?
    It cost me, $16 ish for the filter kit (filter, gasket) and the fluid cost me $26 ish.
    Can't remember exactly, but I got like 10cents back from a $50. I bought a 4Litre bottle of oil and that wasnt just enough. Made a slight mark on the dipstick
    Getting it done at a mechanics, I'd say atleast $200.
  3. mr calais 5.0
    mr calais 5.0 New Member
    victoria
    vy s 2003
    For an hour of your own time and 50 bucks and a nice beer after the job is done.. It's a simple job to do just be carefull not to spill the old fluid on yourself.
  4. FXST01
    FXST01 The Grey Man
    Perth, WA
    VP V6 Exec
    Just to let you know there is no drain plug in the pan, so leave one side half undone so the fluid can drain out the other side of the pan. It's a messy job especially when the pan needs some prompting to come away from the transmission.
  5. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    if your doing it in the driveway i highly recommend laying down a plastic sheet or some cardboard. no matter how careful your are youll always manage to spill a little.
  6. Grennan
    Glen Waverley, Victoria
    VE SSV G8 Sportswagon
    The filter costs about 15-20 bucks from my work. Cant remember the exact price of the kit. 5L of DexIII is 35.
  7. Circlotron
    Is it practical to poke a plastic tube down the filler pipe and suck out most of whats in the pan first, so there would be less to spill when the pan comes off?
  8. DJ_Cosmic_Fire
    DJ_Cosmic_Fire smarter not harder
    South East Queensland
    VP S-Pack Oct '91 - VT SrsII Wagon - VE SV6 SrsII
    Cost will vary between $120 - $150 for basic service - just ring around a few places if you don't feel like doing it yourself or don't have the time. For a full Trans flush & refill it would be $180 - $240.
    DIY would take an hour (for the actual work), can be a messy job - drop sheet & protective eye wear & latex gloves are good ! loosen rear bolts on pan to drain as stated above, follow service procedure from your Gregory's Manual - No.258
    Auto Trans Service Filter Kit VN VP V6 V8 is $17, 5 Litres of Dextron III Valvoline Auto Trans Fluid is $40 (I get 2 bottles - it is always good policy to have some quality clean trans fluid in the garage that matches what's in your car).
    Your looking at an afternoon to be realistic (to allow for purchase of service needs, preparation & clean up) a trip to Repco or Supercheap for $57 (or $97 with 2x5ltr bottles of Dex III) as long as you have a good jack, heavy duty chassis stands & ramps.
    Oh yeh with the syphoning I wouldn't bother as you are draining the Trans fluid via the Trans pan, the tom thumb pump trick is just a quick way to extract a few litres of fluid when you need to get something done without dropping the pan. (eg - adding some Rislone auto Trans repair fluid & topping up with clean Dex III)
