wetwork65
A wet business
- Mar 12, 2006
- 1,373
- 2,057
- 113
- Location
- Sydney
- VF SSV Wagon & VF SV6 Wagon
Hi - I can't get the full detail from searching, hence the post.
Looking to change suspension as title, but I see that sway bars are different from standard SSV to Redline spec. My car has 24mm front, 12mm rear bars per standard (SSV is same as my SV6). I see that Redline is 26/28 (or less in VF2).
Am i correct in saying that if I changed the shocks, springs and did not change the sway bars (the front looks like a complete PITA to change out) then it looks like I would have an "under swaybared" car which would understeer more than true FE3 and I would probably be disappointed with the result. I have driven FE3 so have some point of reference.
Thanks for advice.
Thanks for advice.
