wobbles123
- Jan 18, 2018
- 171
- 78
- 28
- Location
- nsw
- 2008 VE SV6 Auto Ute, 2013 VF SV6 Auto Sedan.
Is there a thread on here on how to remove Air intake Manifold....thanks
It is the SV6 Ute...Feb 2008 built to 2009 Specs....195kW. V6 Engine Auto with 5 Speed Active Select....Alloy Tech High Output.....it has done 123000 kms…..with the engine never been touched....except oil changes at 8000kms, tyres, brake linings etc...never suffered with the timing chain problems...it is not the SIDI which was a later variant.....the good book says change S/Plugs at 120000kms.....thanks for your time...I can do the job myself...but want to know if there are hang ups to look for.....thanks.Is there a thread on here on how to remove Air intake Manifold....thanks
Yes there is some good info here....but does not show how to remove the Alloy air inlet manifold on the sv6 to gain access to the spark plugs....I am able to tackle the job myself....but wish to know if there are any problems to look for removal....I thought there maybe a thread here with some instructions etc.https://www.autoinstruct.com.au
Have a look at this site . Has some good tutorials . Just navigate to the holden section .
.....the good book says change S/Plugs at 120000kms..... .
This is a good guide for your project.Good luckIs there a thread on here on how to remove Air intake Manifold....thanks
Thanks for the video.....I get the idea for the removal of the manifold.....it is exactly as I thought with the removal...I knew about the bolt up under the cowling at the back...but was unaware of what was connected to the back of the manifold....I think I will take FIGJAM'S advice and leave it until I finally do have to do the S/Plugs....I have included some pictures of my manifold.This is a good guide for your project.Good luck
