change spark plugs now haveing lots of trouble
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by scagsdale, Sep 30, 2006.
  1. scagsdale
    scagsdale Guest
    My car is a 2000 Vt Commodore and it kept on dieing on me so I change the spark plugs, now it it will not start and when it does it sounds like a tractor and the whole car shakes,
  2. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
    You have the plug leads on the wrong cylinders or you have buggered them taking them off.
  3. BOGANV8
    BOGANV8 I gotta V8 whoot whoot
    Armidale
    VX 02 SS LS1
    Yeah i would say the leads around the wrong way :thumbsup: :thumbsup:
  4. IBLOWN
    IBLOWN Well-Known Member
    VS V6 TT/'13 VF Senator/'11 WM CapriceV/Hayabusa
    Thats for sure.
  5. deserthead
    deserthead Well-Known Member
    Cairns QLD
    VS III l67 Column Shift Ute
    Sounds like your misiring there champ.
    I'd check all your leads, make sure they r in good condition and are on correctly, did u gap the plugs b4 u put them in?
    You may have a dodge coil pack, ignition module may be gone.
    R u getting any error light on the dash?
    Edit: Dammit u all beat me. . . .
  6. fabz
    fabz I Can Do Science Me
    In My Car!!
    Blown V6 VT commodore 5 speed
    hahaha my 2cents is that its air filter, 100% bet my bottom dollar on it hahaha ;)
  7. hkmonaro68
    hkmonaro68 New Member
    vz wagon
    u didnt drop any of the spark plugs?
    may have cracked one,
  8. Hairy Eater
    Hairy Eater Banned
    Queensland
    2000 VX Executive V6
    look at the coil numbers... each number is the same cylinder number ..... each coil goes to two cyliners .... but mare sure you get the numbers right ... coil number 3 goes to cylinder 3...
  9. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
    Hey Hairy Eater, ABC 123.....;)
  10. VS Roy
    VS Roy Guest
    You have either got a bad set of plugs ( this happens more often than you think) Damaged leads leads wich happen when it is hard to get the leads off because they get stuck on, or you have the leads on the wrong way
