Changed Diff Ratio - How Does it affect the trip computer?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Dogster, Aug 28, 2005.
  1. Dogster
    Dogster Guest
    I have changed my VR Senators diff ratio to 3.73, does this affect the trip computer at all, how can I alter the trip computer to suit the new ratio?
  2. Fekason
    Fekason Fekason
    Penrith NSW
    Calibrate
    The trip computer allows a + or - 25% calibration adjustment to both the distance and fuel flow calibration numbers.
    If the default number was accurate before, then that should give sufficient adjustment to compensate for the change in overall gearing.
    Follow the distance calibration process, and all should be right.
    This calibration won't compensate the speedo though.
  3. ExPrEsS
    ExPrEsS Guest
    You will have to change the gear in your transmission that connects to the speedo cable to suit your change in gear ratio, and then your speedo will be correct, as will your trip computer..
