Changed my motor now it has no spark
Jody Bowerman
Tasmania
2003 VY Executive Manual
Hey guys, I have a 2003 VY executive converted to manual. I bought it converted. Pretty sure it still has the auto ecu and loom as gauge cluster shows it in park. I put another motor in it and now it won’t start.
Has no spark, replaced cam angle sensor, crank angle sensor, oil pressure sensor, coil packs and leads. Don’t know what else to try
Does anyone know what to do to get it running?
Immortality
Staff member
Sth Auck, NZ
Welcome to the forum.
Have you removed the PCM?
Utel67
Tasmania
Vs s3 ute
PCM/ECU is located in the passenger side kick panel,
Was it running before you swapped the motor?
You haven't mentioned swapping the dfi.
Jody Bowerman
Tasmania
Yeah, it was running, tried disconnecting the ECU and plugging it back in with no luck.
ant797
bunbury
vy s
Have you tried looking at fuses and relays
Utel67
Tasmania
Vs s3 ute
Where did you get the crank angle sensor from (if from eBay) try swapping it with the one off the old motor.
Jody Bowerman
Tasmania
It was running before we swapped the motor over. We swapped the DFI over as well and still nothing.
Jody Bowerman
Tasmania
Swapped every fuse and relay for new ones. I got the crank angle sensor from Metro Auto Spares, so it’s a good one.
losh1971
North Tas
VE Series I SS Ute
Deleted re-read initial post?
