changed spark plugs!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by mrVT, Jan 30, 2009.
  1. mrVT
    mrVT Guest
    today i changed spark plugs on my vt not that the old ones where worn out or anything but its been a number of yrs which i havent changed them so i decided to put fresh ones on, my question is do they need regapping cause i did not do the gap i just put them on as they came factory they are gm genuine plugs so i just put em on like that!
  2. sway9
    sway9 The Rejectz Commodore
    Albion Park NSW
    99 VT, Mazda 3 SP23, Hyundai Getz 1.4ltr
    do u mean like a points regap? VT's dont have points and gaps
  3. vxcalais_01
    vxcalais_01 Active Member
    VX Calais 3.8
    Leave them at 1.5mm for a standard car. Bosch plugs come in at 1.3mm. Try to change them at least once a year. I change mine every 10-15,000k's as i am on LPG.
  4. pablo
    pablo Donating member
    Was a 1997 vt v6 wagon
    They should be correctly gapped ex factory, BUT it is wise to check just in case. The NGK plugs have the number 15 at the end of the plug part number, this 15 indicates that the plugs have been factory set to 1.5mm
