Changed the thermostat and climate control is still cold?
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
I change the thermostat today on my Supercharged V6 VS Statesman as it was sitting on the cold mark for last couple of months and now it sits on the 1/4 mark but the climate control is still blowing cold at 25 degrees is there a way to adjust the climate control to adapt or do i just have to leave it at a higher temp to keep warm?
Thanks for any help!
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Check your heater tap is opening
Azp
VN/VR
Also make sure the radiator fan isn't coming on too early and not giving the car a chance to warm up.
pjdm1980
Geelong, Victoria
Must be the heater tap as it started to leak today and i'm about to replace it $48 from holden!
Razedaze
Razedaze
Banks Peninsula, New Zealand
www.razedaze.co.nz
VS Berlina
VS Commodores have a habit of getting an air lock in the heater system, not allowing the coolant to circulate to the unit, try emptying the system then refilling it slowly while the motor is running and is warm/hot with the heater turned on. Good luck!
DannyboyDS
Just hand me the pliers.
35
VS Berlina
$25 man thats good, especially if its for the climate control setups.
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
It just the same as any other heater tap, just have to check how many hose's connect up to urs as there are a couple different types
pjdm1980
Geelong, Victoria
Changed heater tap and not leaking but still cold when under 27 degrees so i will give that a go tommorow!
Fan is not coming on til half way up the temp gauge, so don't think it's that.
Thanks for the help.
88GreenVN
Next Exit Left
Surprise, Arizona
Is the temp sensor attached to the heater pipe?
Has the plastic clip with a copper tip thingo held against the heater core copper pipe.
