Changed the thermostat and climate control is still cold?
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
Ummm
Ummm, Where would i look for that or do i have to pull the dash apart?
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
No dont think so - drivers side down low. Follow the copper pipes back from the fire wall.
pjdm1980
Geelong, Victoria
Will do in the morning.
Thanks 88GreenVN
P.S i don't think you should lend your car to your wife anymore, by the looks of that pic!!!!!
88GreenVN
Next Exit Left
60
Surprise, Arizona
Thanks 88GreenVN
haha - just a scratch......
88GreenVN
Next Exit Left
60
Surprise, Arizona
Also the air mix motor starts to move when the temp is set to 28 deg and up. Just a thought.
VSIIBerlinaL67
35
VX SS M6
what does it say when you press AMB? if its -30c the sensor is unplugged or stuffed. its near the front near the radiator at the bottom little black square
pjdm1980
Geelong, Victoria
AMB works fine it usually only off by 1 to 2 degs
Chirpstr
A new project attack
VR Berlina M5, VP M5
Is the temp sensor attached to the heater pipe?
Has the plastic clip with a copper tip thingo held against the heater core copper pipe.
Can you get a pic of this and how it's meant to be? I'm getting similar issues.
Also a pic of how the flexy hose connects up (the one coming from the in car sensor on back on C/C). I think it goes to a T piece and connects up to one of the holes down there....I think this could be more my problem actually.
88GreenVN
Next Exit Left
60
Surprise, Arizona
I have a CC heater box in the shed - I'll go take a photo after the footy.
