Changed to led lights now interior light only works sometimes and only I break light is working
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by frankey, May 18, 2020 at 3:34 AM.
  1. frankey
    frankey New Member
    glenroy victoria
    vx ss commodore
    I've changed all my lighting to led now only one break light is working and my interior works only sometimes
    And my fron Parker lights won't work. What could it be? It is a vx ss 2001
  2. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    Too difficult to understand.
    Spell check please.
  3. krusing
    krusing Well-Known Member
    Bayside Melbourne 3193
    That was your first mistake, "Installing LED Globes",
    Don't waste you "Time and Money" of LED's in Cars, that were not designed for/with them.
    Been there done that, and replaced the LEDs with Standard incandescent globes.
    Believe me, Standard Globes will last longer than LED's.
    gossie likes this.
  4. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    LEDs are ok. If the fronts are a wedge globe try turning them around. If the LEDs are cheap EBay ones then this could explain why the brake light is not working. Unfortunately the cheap EBay gear tends to be pretty poor as I have found.
    TBH I'd probably not bother any more at $30+ a globe for an LED the cost outweighs the benefit. I have had a reverse LED fail in under 2 years and I popped a standard one back in due to cost. The other one is going the same way and it too will get a standard globe more than likely as I can't justify $70 for a pair of reverse bulbs.
  5. Trevor loves holden.
    Trevor loves holden. Well-Known Member
    vs commodore
    LED are good if you buy SMD style, I don't think you can turn a brake light around as they are 2 in one. I say you just brought the cheapest set you could find. I've got SMD in my interior and reverse lights as they are much brighter, wouldn't use them as parkers or any other lighting. My reverse have been in for 10 years but I don't drive in reverse to often. If they flickering either its not a good connection or stuffed diode in the led.
  6. losh1971
    North Tas
    VR Ute V6
    I paid around 15 -20 a pair for my reverse bulbs and they were great until they crapped out, flickered. Jaycar sell good ones but 35 a piece is hard to justify for reverse light when a 12v flood light is less than that and gives a better light.
