Changes to Brembo Caliper brake pads from Bendix
Discussion in 'BENDIX – Put your foot down with confidence.' started by bendix, May 8, 2019.
  1. bendix
    bendix Member
    VL Calais Turbo
    This Brembo caliper has been fitted to many vehicles, and has had many disc pads with different wear sensor, groove and chamfer configurations to mitigate any noise.
    All friction causes vibrations, and most brake and suspension components have natural frequency they vibrate at. If the Pad or Caliper’s natural vibration frequency matches the vibration frequency coming from the friction surface it becomes an audible noise.
    The standard approach to stop noise was by adding a noise-dampening shim on the back. Recently another approach was created, weights were added to the pad to change its natural vibration frequency, so DB2358 was developed from the original DB1678.
    With the introduction of DB2358 it was found that the large round weights could come into contact with the inside of the wheel rim on some wheel designs. To rectify this the shape of the weights was modified so that they don’t protrude from the caliper as much.
    We are reintroducing the DB2358 with the modified weight design.
    Follow Bendix Brakes on Facebook HERE.
    To learn more about the Bendix Brakes range of products visit: www.bendix.com.au
  2. Daniel Souza
    Daniel Souza Active Member
    Glenwood
    VF2 Wagon SSV Redline
    Now they look much more like the factory pads.
    I installed the DB1678 a few months ago and since then I been fighting with brake noise. Used Bendix grease but no luck.
    Any specials for unhappy DB1678 users ?
  3. bendix
    bendix Member
    VL Calais Turbo
    Hi Daniel, PM me your address details and we will send you out the new version to try. Cheers Admin
    losh1971, VS 5.0, knighty92 and 2 others like this.
  4. Daniel Souza
    Glenwood
    Hi Bendix,
    That would be very nice.
    I have PMed my address.
    Thanks
  5. Trevor loves holden.
    Trevor loves holden. New Member
    vs commodore
    I was told since they moved to china Bendix products ant that good any more, I was told you cant beat genuine, I'm giving Protex a go they are more meatier than Bendix.
