Changing coolant in VE series 2
swmcl
Toowoomba, QLD
VE 2 sedan - ex police
Hi,
Simple question and simple task - or so I thought ...
Pulling the lower radiator hose off and taking the filler cap off released some fluid but not much. I'd like to release a lot more!
Is there anyone who has done this simple job willing to let a few uninitiated into the secrets?
Cheers,
Steve
greenacc
Searching for the billion
VE Berlina
There's no secret drain plug that does the whole lot sadly, though on the series 1 and probably 2 there's a blue plug on the bottom of the rad that lets you drain it without removing the hose. After you drained it as you did if you want to flush it all out you just have to fill it with water, run it, and drain it a few times until it drains clear then top it up with the right amount of straight coolant to get the mix right with the amount of water that's already in the system.
Don't forget your heater is full of coolant as well so it's impossible to drain it completely. Pretty sure a Holden dealer would use some sort of flushing system to do this..?
Xplaya
NZ
HSV
Any tips on how to get this right ? Since you say there is still water in the system that we cant fully empty? Any idea how much water is left in the system or is it once you finish the last flush of water as much as you can, you are safe to just go with 50/50mix?
gossie
Gold Coast.
VE International 3.6L
Do make sure to use RED coolant as is in the VEs from new.
Ron Burgundy
NSW
VF II SS
This is exactly what i did...
Drain coolant on bottom plug on the radiator.
Fill with water.
Repeat 2 more times.
Once drained 3rd time fill with 5 L concentrate of dexcool coolant from holden.
When i drained it 3rd time the water was almost completely clear.
Think about it this way
First time you do it you coolant to water ratio is 25% as from the factory it's 50/50
Second time it's 12.5% coolant left
The third time it's 6.25% coolant vs water ratio
You get the point
I basically drove my car for 1 day after each drain/refill
From memory only 1/2 of total coolant capacity drains when you undo the drain plug
Xplaya
NZ
HSV
So you took like 3 days to do the flush? Any reason why you did it this way?
i was planning on just running in neutrel for say 5-10mins before flushes? Would that be efficient?
Ron Burgundy
NSW
VF II SS
Yes, 2 days
2 reasons
The thermostat does not open up until it reaches full operating temperature so it will not mix plain water with rest of the coolant
Also, bad idea to add cool water to hot system.
I basically drained it Friday evening when the car was cool and added cool water.
Took it for 1/2 hour drive and left it overnight.
Drained it in the morning, topped with water, went for a good drive and left it.
When it was cool on Saturday afternoon i drained it and added clean water again....took it for a drive and left it to cool
Drained it on sunday morning and added 5 litres of concentrated coolant and went for 1/2 drive...
I also completely emptied overflow tank and filed it with 50/50 mix in the end
I know it seems like 3 day job but in reality you will only spend 1hour max to flush and top up 3 times + some driving
VS_Pete
Donating Member
You run the heater don`t you?
Ron Burgundy
NSW
VF II SS
yes, but I believe on VE coolant constantly circulates through the heather core...
I remember reading something about it not long ago...
Xplaya
NZ
HSV
When i took my car for its first service, as you do when you buy a new car (i think) :) (I only owned it for about a week so didnt know much about it) they also put the green stuff in?
My question is doing a flush like above good enough to change it to the red coolant? Or is there other components that need checking now? I read mixing them is not a good idea?
