Changing Leads
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Redhsvxu6, May 8, 2008.
  1. Redhsvxu6
    Redhsvxu6 New Member
    VT HSV XU6
    Hi all
    This site is the best.
    Is there a trick to removing the spark plug off the plug with heat caps.
    Not sure how much i'm to give the little f@cker
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    Twist the rubber boot as you pull. They can be hard to get off if they have been on for a long time. Just be careful not to pull the end off the lead. Since you are changing the leads I guess it won't matter if you wreck them.
