And then its under the 1 gear indicator
It is hard to see but if you get down low you can see where the wire goes into the connection
I recommend sticking your phone in and taking a pic or 2 to reference the wiring and connector
The connection needs to turn anti clock wise to remove, if I remember correctly
If you have thick sausages for fingers you are going to struggle
