Changing ls1 oil pump
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
hi people my mate has asked me to change the oil pump on his ls1
just wondering if anyone had done this and whats involved im pretty clued up with
this stuff i built many many motors ,but have never changed an oil pump on a ls1
how hard is it,cheers any tips will be good thanks guys . . . . .:thumbsup:
p.s I want to do it in the car not with the motor out
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
sorry the car is a vx ss
crew chief
WK Stato with blurred plates
Pull the radiator,belts and balancer remove water pump and timing cover will have to pull an idler pulley to get at one of the bolts and presto there it is.
vt1538
455rwhp LS3
52
The Dead Centre
VY SS S2 [email protected]
One thing that how to doesnt tell you is it is better to buy a bolt an inch longer than the crank pulley bolt to get it started when reassembling. There is a chance that you can strip out the thread in the crank if you dont do this due to not enough threads being engaged. Otherwise it is a very good right up.
When I did my cam change etc I didnt bother with the dropping of the sump. However this method can have a few dangers & is not recommended for the inexperienced.
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
cheers for all your help guys your all legends
Munz
Right Foot Action
Brisbane NTH
VZ Calais LS1 / VL RB30e daily
depends how competent you are with tools, between 2-5hrs would be a gueestimate
Potz64
56
West Australia
Vx ss commodore
I was told you have to drop sump to get at Oil pick up bolts do I have to lift motor or is there enough Clarence
