koges
- Sep 17, 2018
- 3
- 0
- 1
- Age
- 56
- Location
- swansea 2281
- VF CLUBSPORT
My clubby has a MAF sensor fault , is this easily changed or do I need my mechanic to do.
You can do that your self it’s very easy,if not sure just study it for a while and use your fone to take fotos,disassemble and re assemble,only tool you will need is a good flat head screw driver,unclip wiring harness,undo airbox clamp,pull air intake tube towards you,undo clamp on eng side and pull maff off,on reassembly make sure you have the arrow on maff pointing to engine,put maff on and wiring socket is pointing to air box,push on air box n tighten up clamps,engine doesn’t need any resetting,just start n enjoy driving.
Has just started running rough , had to get inspection for rego and asked my mechanic to have quick look if he had time , hooked up to computer and came up with engine p0102 fault .As you need to ask how to do a reasonably simple change over job, how do you know the MAF sensor itself is the actual reason for the fault?
