Changing O2 Sensors, How To?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mrhotdog, Jun 15, 2008.
  1. mrhotdog
    mrhotdog What Would Jesus Do?.....
    Adelaide, South Australia
    2003 VY S1 Acclaim
    hey
    can anyone tell me how to change the o2 sensors on the VS?
  2. DannyboyDS
    DannyboyDS Just hand me the pliers.
    VS Berlina
    its pretty simple.
    jump under, unplug them from the loom, unscrew from the Y piece of the exhaust.
    apply anti sieze to the new ones, screw them in, plug them in, and WOLLA!
    I know thats not 100% perfect the HOWTO but there isn't allot to it.
  3. immortality
    Sth Auck, NZ
    they are probably stuck. if they don't move try it with a hot exhaust. if that doesn't work, spray liberal amounts fo CRC or WD40 onto threads of O2 sensor. it should hopefully loosen em
  4. ephect
    ephect Donating Member
    VS Acclaim V6
    just dont spray CRC on a hot exhaust! :)
  5. immortality
    Sth Auck, NZ
    why not, you get some smoke, the heat actaully helps pull it into the threads. i didn't beleive it until someone did it at work after heating something with the gas axe. worked a treat
  6. ephect
    VS Acclaim V6
    i thought it might ignite is all. but ima take your word for it, with a lil caution
  7. OldDog
    OldDog Donating Member
    Mudgee, NSW
    VF Series 1 SS Storm Ute
    Ya learn something new every day. Thanks:thumbsup:
  8. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    CRC won't ignite on a hot exhaust, it doesn't get hot enough, it will just smoke and stink a bit.
    If you can change a spark plug, you can do an O2 sensor.
  9. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    I sprayed it 2 days prior. I used my leg to undo it and when it went it kained my leg belted it on something and was limping for 3 days. I think its a 1/2 (20cm)
    I cut the top of mine by the way with bolt cutters so I could fit a socket over the mongrel then used a breaker bar with my leg.
    Have fun!
  10. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    I'm pretty sure they are 18mm.
    1/2 what Wavez? Haha, 1/2" is only 13mm. 20cm is like 8".
  11. Chirpstr
    oh crap. your right lol. my bad, randomness. I think it must be 22mm. I remember now. bahahaha cheers abbafan!
  12. DannyboyDS
    VS Berlina
    thats actually not a bad idea, I might try that next time I cant get a set off, I generally just prefer to use anti sieze when installing them :p
  13. immortality
    Sth Auck, NZ
    thats good when fitting a new one, unfortunatly the the guy who fitted the original didn't care about the poor bastard who had to take it out in 10 years time. the last time i bought a O2 sensor it came with anti-seize already on the threads
  14. Chirpstr
    yep it's got that thread muck already on it.
