Changing parts between series 1 and 2??
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Burto89, Jun 7, 2009.
  1. Burto89
    Burto89 New Member
    Gladstone QLD
    2004 VZ S-Pack Ute
    Hey guys,
    just asking a quick q for a mate. He was wondering if you are able to swap parts from a series 2 S Pack eg. (S pack cluster, door trims etc) to a series 1 excec commy?
  2. DUK13Y
    DUK13Y When in doubt, slide it out
    Sydney, Australia
    VEII SSV, VYII Berlina, '97 Lancer
    I don't think you can swap the cluster as some of the gauges will read backwards. Please someone correct me if i'm wrong.
  3. crewsy
    crewsy New Member
    Sierra
  4. alien
    alien New Member
    Tullamarine, Vic
    03 VY Supercharged 3.8L
    Gathering it's int eh VY section, i presume Series 2 to Series 1.
    Door trims and all that other stuff yes, bodywork didn't change. However, as for the cluster, not too sure on that one. You might have to change over the BCM as well. But not 100% sure.
  5. Fekason
    Fekason Fekason
    Penrith NSW
    Be Careful!
    The clusters are a straight swap between the same series, though the cluster may need a Tech2 programming at your local dealer to be set to your car.
    As previously mentioned, if you swap S1 and S2 clusters, the fuel guages will work back to front and make your DTE useless. This can be solved by changing fuel sender units at a cost of about $400 (three years ago). Best to make sure that the cluster is from the same series.
    In the VY, the change from single window trip copmputer to three window is a straight forward swap as well provided it is from the same series. A Tech2 programming and away you go. However, the odometer can only be reset to your car kilometres in a new cluster (less than 100 km), unless you take it to an instrument overhaul facility.
  6. revv_head
    revv_head I DRIVE A V6 SS :P
    Sydney, NSW
    SS
    hmmm now to find a series II S pack crashed with 20,000 km on the cluster :p
