check engine code P0020 HELP
clutch1967
shepparton
04 SS , 06 ve sedan , 79 VB SLE
I hav a 06 ve 6cyl
Its putting check engine light
I checked it and it is P0020 code problem is on bank 2 it says
I looked on net and it says electrical problem in sensor or wiring on sensor in bank 2
but talked to mechanic and he says its timming chain needs dooing
it runs good no noises nothing I dont want to do timming chain then find out its a wiring problem
Any ideas as to fix
I swapped the cam position sensor from bank 1 into bank 2 , and bank 2 into bank 1 to see if code would change side but it stayed the same
any other ideas or even info about thanks
