check engine light comes on
paynie
WA Mandurah
ve ss ute
after installing a xforce 2.5 cat back system, russo maf enabled otr and had a performance tune the check engine light came on.
After taking back to tuner advised that the rear O2 sensors on exhaust don't even come into equation. Why do they even put them in? They are not even recognised by computer.
Does not effect tune or performance.
The engine light has gone away for now???
But why when cold does engine race, idles high before settling down, then up comes check engine light?
Anyone had this problem error code says rear o2 sensors, replaced and check wiring no good computer does not register them anyway. This is on standard tune and performance tune
But this ute is still putting out 240rwkw goes like a rocket and gear changes so smoothe glad got manual.
Thoughts??:bang:
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Take it back to the tuner and tell him to fix it.
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
who tuned it was it wa perf
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
the rear oxygen sensors are only there to make sure the cat conversters are working correctly, sometimes if you fit high flow or aftermarket cats, they can trigger codes as the oxygen/monoxide etc content alters
paynie
WA Mandurah
ve ss ute
na wasn't the tuners fault it did it whne the car was not tuned.
Been 4 days and no light has come up. Might of fixed itself.
Wa Performance did a great job.
paynie
WA Mandurah
ve ss ute
Cheers for the info
paynie
WA Mandurah
ve ss ute
light is on again grrrrrrr
Off to Holden to get the error code read.
hmmmmmmmmmm
